SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Auto leveling Xenon lights stopped working after accident
Old Dec 26, 2012 | 12:41 PM
URNVS's Avatar
CLK350
I have a 2000 500SL that was hit in the front left. After everything was put back together the lights point straight down into the ground. Is there a separate connector for the leveling motor that the body shop might have missed when they re-assembled everything? If not, how do I go about troubleshooting the cause?
Old Dec 26, 2012 | 05:48 PM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
You will need to reset the ecu...... To do so you will need the star diagnosis tool.....
Old Dec 26, 2012 | 05:56 PM
URNVS's Avatar
CLK350
There is no way to confirm that the motors do/dont work and that everything is connected properly without having to pay at the stealership...?
Old Dec 26, 2012 | 07:03 PM
SL BRABUS's Avatar
Headlamp Range Adjustment (HRA) control unit.
Rear axle sensor HRA
Front axle sensor HRA
One of those is your problem.....
Most likely your problem is the Headlamp Range Adjustment (HRA) control unit.... From what I read in other forums.....
Old Dec 27, 2012 | 10:49 AM
URNVS's Avatar
CLK350
I saw that thread about the control unit the other day, but since it was working before the accident and the body shop had to remove/replace the headlights I thought it was more likely that perhaps something simply wasnt connected properly.
Old Dec 27, 2012 | 02:18 PM
SL BRABUS's Avatar
If you feel that way..... I recommended you to take it back to the body shop and have them find out what the problem.... Since they did fix it right....
Good luck...
Old Dec 27, 2012 | 03:14 PM
URNVS's Avatar
CLK350
They are pretty good at painting bumpers and fenders, but not so much at high end German car electrical systems so even if I take it back there I have a much better chance of actually fixing it myself :P Thats why Im trying to get information on how this system should be connected together, and how to troubleshoot it.
