SL/R129: ADS Fluid change
Thank you for your reply. Please explain your method.
Thanks,
Mike P
SL65(29miles) 600SL(51) 560SL(262) 560(41K) E300D(42K) 240D(318K!!!!)
The manifold is accessed from under the vehicle ( i used a lift so I could inspect all the system, and replace all that had been crushed by the deer. ) The belly shield was taken off first, that exposes the hoses, tubing, oil filter and the leveling hydraulic system. The manifold is on the passenger side wheel well toward the motor from the front wheel. You can also get to the manifold from the wheel well after the front tire is removed. In the "world of MB's you can search for ADS and find great detail about the distrubition block and the leak problems and rebuild procedures.
If I needed to rebuild that manifold I would send it to Klaus at Top Hydraulics, just I have done with the RST cylinders.
Mike, Nice collection listed, Where in the world are you?
- A couple empty gallon milk jugs
- A long piece of plastic tubing
- Denatured alcohol from the local hardware store
- 4 liters of ADS Fluid
Some folks will say that’s too much fluid. However, I like a very clean hydraulic system and the smallest of particles will cause valve block leakage. The more fluid you purge through, the better the chance of flushing out small particles. That’s just me.
Procedure:
Warm up engine and activate the ADS System a couple of times. Once the engine is warmed up, turn off engine.
Remove the ADS return line at the top of the ADS reservoir tank. Connect a long plastic tube to the end of the line, placing the other end in an empty gallon jug.
Remove the sieve filter and assembly from the ADS reservoir.
Using an old syringe, withdraw as much old fluid as possible.
Fill ADS reservoir with fresh fluid. It’s OK to overfill but don’t take it to the brim.
Have the assistant start the engine and watch the fluid transfer into the milk jug. Always watch the ADS fluid level and add more fluid as needed.
CAUTION: If the ADS Fluid level gets dangerously low, have the assistant immediately turn off the engine until the reservoir can be filed again. Under normal engine speeds, you should have no problem keeping the reservoir filled.
With the engine idling, have the assistant activate the ADS system at least twice. Watch the ADS fluid level carefully as the system is activated. As you get used to the fluid discharge, the engine can be rev’d a bit to speed up the process.
Return the ADS system to its normal position (not elevated). By this time, the fluid should be coming out clear with a greenish tint.
Turn off the engine.
Clean the Sieve Filter with denatured alcohol. Alternatively, you can replace it. Ensure the Sieve Filter is completely dry before reassembly.
Reinstall the ADS Filter Assembly and reconnect the ADS return line.
Start the engine and adjust ADS fluid level as needed.
Done.
Cheers,
Jeff
Using a DIY from a Dannish Benz owner I hung the wheels ( pressure off the system ) and removed the front wheel housing covers. I then loosen the "slip apart" mounting structure and removed the spheres ( no bold/nut removal ). They were completely fill with hydraulic fluid. The ride is back and I have another DIY mission accomplished.
I guess the fluid lasts as long as the spheres 20 years for the front, and so far 10 years + for the back!
Cheers,
Jeff
The deer strike was an 18 wheeler "chew up and spit out" the carcass, at which point the rainy interstate and traffic gave me no choice but "jump" the tumbling mass. the hard parts (antlers? ) became selective in their damage. I bought all the accumulators, just in case the back need renewal.
Maybe the heat of SA make the degeneration faster?? When I was stationed at BAMC the interior of my Jag E and 280SL took a lot of "Hide Food"
Cheers,
Jeff
PS - Thanks for serving. Navy vet here; Vietnam-era.
I have in inventory the rear spheres, do you have a feel for the shelf life of the nitrogen barrier?
Army 66-83, did not retire. HSC didn't need an Orthodontist one star? ( ego stuff ) You may be the only Navy person in San Antonio!
Thank you for serving.
Regarding SA Navy... Yup! Literally a fish out of water - in more ways than one. LOLx2
Cheers,
Jeff
USN 73-83
