SL/R129: srs light stays on for 2 min then off
Everytime I start my SL 500 1994. The SRS light comes on within 2 minutes it goes off. I've read quite a bit about the seat belt going bad. Do I need to remove the seat and disconnect everything and clean all the pins? Because I cannot find a SRS Fuse in any three fuse box locations? Thanks Tracey.
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
Contact may be an issue, but within two minutes it does get the connected message? I have not had a problem that with "more time" corrects! I have had the seat apart and less than completely connected the seat belt connector, but once connected the light delay was a few seconds.
Good luck on your search.
