SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Dash Code -111, -112, -113
Old Sep 14, 2013 | 10:13 AM
DanBurkhart's Avatar
1999 SL 500
My wife receive codes -111 and -112 codes on the dash display on 1999 SL500. I assume they correlate to OBOII code relating to MAF issue.
Later I downloaded OBOII codes and only received P0715 which has nothing to do with MAF.
I don't have a problem replacing the MAF if it is truly bad. How do I verify?
And is the P0715 potentially associated with a transmission sensor issue?
Lastly I need a recommended link to download 1999 SL500 service manual.
Old Oct 16, 2013 | 01:19 PM
TheSaint's Avatar
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
I know this is a late reply but to verify the codes i would rest the the error codes and see if they come back
If the codes does not come back then i would assume everything is on order
But if they come back fast then you have a fault you need to repair
I did a search for error code P0715 and this is what came up:
OB15 MB Description
00715 P0715 Input/Turbine Speed Sensor Circuit Malfunction
