SL/R129: Anyone changed fenders/wings?
Some R+R's I've seen fail to mention this part, I also then wonder where the bottom part of this bracket attaches or hooks on to.
Any help appreciated thanks
Not rushing into this job until I am sure exactly what is involved. Even if not painting the new wing/fender, I think a person must consider painting the inside of the panel where it would be seen when the door is open and also some precautionary paint protection of the inside of the panel/arch lip seems sensible, so all told, not quite as easy a job as it may first seem/
I am not deterred yet though!
You have to take off the inner plastic fenders and the front bumper
The most work will be when you put the fender back on when you have to align the fender towards the doors and hood to get an even gap
One time i took off a fender on a car i had i used a marker pen and drew around the washers to the bolts that attaches the fender to the body and when i put it back on i just had to place the washers/bolts inside the circles i had marked and that made it really easy
But this only works if you are putting back on the same fender off course
I wonder if you can do me a favor by taking pictures of the inside of the front fender above where it meets the front bumper as shown in the picture
I have got a rust spot i need to cut out and weld in new metal and if you can take a picture of the area marked in red of the inside of the fender i will see if there is a double plate of metal there as somebody told me
I belive and hope that there only is on metal plate because of the repair i have to do
I have sent you a PM with my email address
