SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 2001 Armrest Stuck Closed
Old Nov 12, 2013 | 04:15 PM
ikedeloix's Avatar
R129 SL500
Hey anyone know how to open the armrest the button on the side closest to the driver seat does not work ?!
Thanks !
Old Nov 13, 2013 | 04:34 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
In my old R129 I might have a "lock compartment" I can't open because the vac lock system is broken, or still Locked.
The solution for the last example requires the key placed in the key slot near the airbag and being rotated. If the vac system is operational the door map compartments, center console and back compartment areas will all "click" unlocked!
Hope that is part of an answer for you.
Old Jul 28, 2023 | 05:00 PM
erickSL500's Avatar
Sl500 1996
It works!
Thank you for the answer. Had this issue today and it worked like a charm. Kudos to you!
