SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Power antenna
Old May 4, 2014 | 03:04 PM
Staylor229's Avatar
2002 SL500 Mercedes Roadster
Power antenna
How do I remove and replace the power antenna on 2002 SL500 Roadster?
Old May 5, 2014 | 12:53 PM
cliffyk's Avatar
1998 SL500
Referring to the diagram below (and assuming you have a 2002 R129):
  1. pull back the trunk trim to access the antenna unit, it helps to remove the left tail light's inner panel;
  2. remove screw #77 that fastens the ground strap;
  3. remove the electrical connector, #82;
  4. remove screw #78, this is the only faster holding the antenna in place;
  5. pull the antenna unit down and out of the fender grommet, remove the unit--this can require some wiggling and maneuvering;
  6. disconnect the RF cable (#81), or cables--if your car has the optional cell phone or other options there may be an amplifier box connected to the antenna mast housing, with multiple RF cable connections;
Old May 7, 2014 | 11:58 AM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
Is your mast not moving? Is there an electric motor sound? did someone bend the mast? All of those issues and be repaired with part not replacement of the entire system.
The repair once the motor is removed is easy, but plastic parts do break!! be gentle
