SL/R129: Key sticks in ignition, always come out after a delay?
I could assume it is the same issue and same solutions, but not sure since I have not found a single hit on being just stuck.
The interesting thing is that it always pops right out after a few minutes. It also works quite well for a while after I spray wd40 in the tumbler.
Was wondering if I should spray a higher viscosity grease in the tumbler?
I don't know if other MBs have the same issue, but the SLs have it for sure. You have to put the car in park and release your foot from the brake.
It is also a dielectric and a much better lubricant than WD-40; which is not an especially good lubricant and was not designed to be one anyway--it was engineered to displace water/moisture, that's the "WD" part...
Thanks for the recommendations!!
Here's a link to the 1998 OM (4.5 MB PDF)...
