SL/R129: M119 temp question and door window adjustment
Got a 95 sl and wanna kill two birds without flooding the page.
Temperature is running at 90c majority of the time after replacing open thermostat. Used an oem 'stat and zerox 50/50.
Outside Temperature is usually 80f. I replaced the reservoir with an updated one off a 2001 model and it seemed fairly new (plastic was still clear). The original cap neck had a tiny leak so that why I swapped it. The original stat ran 85c in south Florida heat but took a while to warm up. The new one seems to creep to 95-98c sometimes and really takes some driving to bring it down. Is this normal? Will stay at 85 until I start heavy speeds or distance.
As for window adjustment, it seems the windows are over traveling and you can see them push up on the hard and soft top making a creaking noise at the top of the door. It'll make a creaking noise if I flex the window by hand when door is open so I assume something's loose in the motor assembly. The windows are also slightly tilted aft making a tad bit more effort to close. Can I make both height and angle adjustments INSIde the door panal at once? And how so?
Thank you!
Open your hood, if the electric fans haven't started ( with the AC off) your problem is the sensor that put it on operation. It has one for the gauge and one for the fan, is a resistance type, that sends 4 speeds to those fans.
The AC only put 1 low speed.
AC low pressure hose blew and am going to have it repaired.
Never had the aux fans kick on but temp has never gone over 98-99c
I have used a couple laser thermometers which show temp is reading well BuT the temp gauge on the dash sticks. I have to repeatedly tap on it to get the needle to move. I will be removing that soon. Previous owner had a light bulb changed and may have screwed it up.
Fix that first and if the problem persists, which I think will not, check the fan clutch and perform a radiator flush ( you can also do it, it's never a bad idea)
The fans come on low-speed if the outside temperature is 30C or greater and the A/C is running.
could borrow an ohm meter.
I'm putting the ac on hold until I put new rear suspension/struts, and flex discs on.
Also, fan clutch seems good. Shortly after shutdown, you can turn it pretty easy but will stiffen up a lot the more you turn it. I assume that's a pass grade?
Btw, can I drive the car with the low pressure ac hose removed for repair?
Yes, just make sure any openings are covered to prevent debris from entering the system.
I'm worried I didn't bleed air out of the system properly. When I did the thermostat, I just removed the top hose and the thermostat Israel's w/o draining the radiator but I did refill properly and it's been over 6000 miles already. I just fixed my temp gauge as well. Still reads right without knocking on the dash.
Clutch fan works 100% as it should. The car will operate At normal temperatures on highway speeds until I get off and they creep to 90-95 and lingers there. At idle while revving it will go to 100c but revving in in the 1600rpm range with the clutch fan roaring will drop it. Turing the heater on will drop it very quickly as well.
Thank you!
