SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Signal switch
Old Jul 19, 2017 | 12:50 PM
rscruggs2's Avatar
SL500
Signal switch
My 1999 SL500's signal switch is not shutting off after turning a corner both right and left. Do I need a new signal/wiper switch or is there another idea?
Old Jul 20, 2017 | 03:20 PM
rscruggs2's Avatar
SL500
Originally Posted by Plutoe
You either have a faulty front SAM or stalk---you have diagnosed the issue right??
No and I don't know what a SAM or a stalk is other than deer hunting and Sam hill! What I do know is that the whole insides move up and down a bit like something is worn inside......both the turn signal and cruise control.
Old Jul 20, 2017 | 03:59 PM
rscruggs2's Avatar
SL500
That being said, you have a BA problem!---Go to the yellow pages and look under house painters!
Thanks for your help.....I was merely offering some humor in my lack of automotive repair skills.
Old Jul 20, 2017 | 04:28 PM
rscruggs2's Avatar
SL500
I suspected that and that's why I added to the humor---your issue is not a front yard or curb side DIY!!
I found an old thread on the subject which read "I was told the cause of the non cancel issue was the boot or surround over the column was loose, which in fact it was. My independent drilled a small hole in the bottom of the column and repositioned the boot and tightened everything up. Seems to have solved the fast directional as well as the cancel issue.
If you are a DYI person I've seen threads here on doing the drill routine but I just wasn't comfortable drilling a hole when I don't know whats behind it."
This looks cheaper than buying a new switch!
Old Jul 20, 2017 | 06:06 PM
sneezix's Avatar
1997 SL600, 2017 AMG GTS
You are correct. It helps, immensely if you take off the steering wheel. And, if you remove your instrument panel, then you don't need to drill the hole. I drilled the hole, though.
If you over-adjust, your steering wheel will squeak.
Frank
Old Jul 30, 2017 | 10:49 AM
miike's Avatar
2002 G500, 1961 190b, 2001 SL500 Sport
I have replaced the switch in a C class. It's doable but not fun. You'll need to have the airbag code reset after you disconnect them in the steering wheel. There was a YouTube video for the C class and owning both cars, I'd bet you could use that to figure out the SL
