SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Ac
Old Aug 12, 2017 | 04:00 PM
Duongng1956's Avatar
2001 SL500
Ac
I have a 2001 SL500. When I start the car, the ac would run for about five mins. Then it would cut off,then run again for another five mins. Then it would cut off again. Cold air still blows through when it runs. Do you guys know why this would happen and how do I fix this problem?
Old Aug 13, 2017 | 08:59 AM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
where what when
Where in the world are you?
What have you done with the vehicle?
When you say it operates that does not include holding the car cab temperature? the fan speed changes? or the system does nothing, fan cool lights on panel?
Lots of help but some of us need more information.
Old Aug 13, 2017 | 01:32 PM
2001 SL500
I live in Houston, Texas. I just bought the car about a month ago. Everything was working fine when I bought it. Can you please rephrase your questions that you are asking me? It's confusing what you're trying to ask me. My ac has been having problems about a week ago. I don't' know what to do with it. When it blows air the fan works fine. The fan's speed doesn't change, it works fine. It would cut on and off as I am driving.
Old Aug 13, 2017 | 07:18 PM
Jimmy Chen Shib's Avatar
1994 AMG E60 (W124); 1997 SL600; & few others that I cannot fit in here
Had a similar issue with my 1997 SL600, which was the first time it occurred. Took the car in to my usual shop and they replaced a simple part (somekind of regulator, I believe) and got fixed with relative ease. Sorry but I am not mechanically versed.
Anyway, the problem should be straightforward to resolve.
w/ smiles
Jimmy
Old Aug 13, 2017 | 11:59 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
It's ambiguous to me what you mean by the A/C cutting-off. If you mean no air flows from the vents, then you likely need a blower regulator. If air flows but it is not cold, the compressor may be cutting-off, or hot coolant may be flowing into the heater.
Clarify the ambiguity for further detail.
