SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: oil is full, but low oil pressure
Old Oct 2, 2017 | 12:10 PM
JunoJim's Avatar
SL 550
1997 Mercedes SL 320
Old Oct 2, 2017 | 03:27 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
Oil weight?
synthtec or traditional
instrument panel or separate instrument.
Old Oct 21, 2017 | 07:19 AM
fitznj's Avatar
sl500
volume vs pressure
Oil volume (assuming you have oil in your engine) and oil pressure are not directly related. Low oil pressure is
a sign that your crank bearings are wearing (usually the main bearings); A worn oil pump may also reveal low
oil pressure and thinner oil will show similar signs.
What are you oil pressure readings and at what revs? Modern engines tend to run lower pressures that in the
"good old days".
How are measuring the oil pressure ?
