SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: R129 SL600 integrated thermostat housing
Old Jan 12, 2018 | 06:31 PM
bzracer73's Avatar
R129 SL600, R230 SL55. C215 CL65
Hey all.....new to the forum....recently procured an 01' SL600....love it!
Doing some maintenance to the car and thought I'd like to put in a lower thermostat so the car runs cooler....I've heard the M120's run a bit on the warm side inherently....
I know stock is 87 Degrees Celsius and I've just purchased an 80 degree Celsius thermostat...I believe it is Beck/Arnley
My question to you all is........How in the hell does the thermostat separate from the thermostat housing???? I cant figure it out....
Or does it not separate and you need to replace the whole housing w/thermostat????
Also what thermostats are you running on your M120's?
Any insight would be greatly appreciated....
Regards,
Brian
Old May 6, 2018 | 10:21 AM
White500SL's Avatar
1998 SL600, 2017 GLC300
Hi Brian: not sure if someone answered your question, But on these cars the housing and the thermostat are all one piece. Make use your fan clutch is good, they make a big difference.
