SL/R129: R129 Electrical / starting issue
It is a 1992 500SL and the Vin # is: WDBFA66E7NF041340
i do have the same problem in my 500sl 1992 , did u find the solution ?
When i turn the ignition on usually i do hear the noise of the fuel pumps for half a second , mine sometimes the pumps dont works when the ignition is on ! So i checked the fuses box all is fine and i do check the mass module its also working well !! When i had this problem and i didnt hear the pumps working i took off the mass module off and i try a wire between the soks number 2 and 22 nothing happened!! I did also cheked the over voltage fuse and it is fine ! I get under the car near the fuel pump and i test the wires i didnt find any electricity in the wires to the pumps !! The second day i try to turn on the ignition everythings works well !!!! So had this problem so often !! A day the car start fine and another day don t !! When it turn on it doenst stop at all ! Tnx for help
