SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 93 Sl500 no start issue
Old Mar 23, 2019 | 10:58 AM
zuru007's Avatar
94 e320 convertible
Hello. I have an issue with my father's 93 SL500. I replaced wiring harness and changed the fuel filter. After the work was done i started the car with the rear part of the car raised to check for any fuel leaks. Car started with no problem at first try and run well. After few minutes i shut it down to put the wheel back and to lower it back to the ground. Unfortunately, the car does not start anymore. All it does is beeps 4 times when I turn the key into the start position. I checked all fuses, fuses in the overvoltage relay. It does exactly what the car in this video. I am located in the Harrisburg PA area, maybe you can recommend a mechanic who specializes with these cars. Preferably someone who could do diagnostics in my garage.
Here is the link to the video showing the issue,
Old Mar 23, 2019 | 01:16 PM
pjacobs55's Avatar
MY2000 SL500
Just a shot in the dark: I'd try disconnecting the battery for an hour, re-connect, and try again.
Hope you get it running.
Peter.
Old Mar 23, 2019 | 06:59 PM
zuru007's Avatar
94 e320 convertible
Disconnecting battery does not help. I made a video of what is exactly going on. Cat starts to beep when you turn key to II position.
Old Mar 25, 2019 | 09:58 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
The starter circuit goes battery -> ignition switch -> K38 alarm relay -> neutral safety switch -> starter solenoid. I'd have someone turn the key to the start position while someone checks for voltage at the neutral safety switch proceed from there.
