SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Instrument warning lights on
Old May 28, 2019 | 05:33 PM
jpnascar's Avatar
1999 sl500
99 SL 500, yesterday all the warning lights turned on, check engine,abs temp etc ,speedometer, tach not working, gas gauge and clock are working ,now today car wont fire up, anybody run into this before??
Old May 29, 2019 | 02:45 PM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
I had the same issue in my 95 SL. I had a cracked (not blown) fuse in the #9 spot. May not be your issue because I have bullet fuses but worth a shot to check.
Old May 30, 2019 | 10:38 AM
Kebowers47's Avatar
001 s600, 94 sl600
Try disconnecting the battery for 15 min to let everything 'go to sleep' and retry. The car obviously has/had a 'grand-mal seizure.' Any number of intermittent 'bad connections' can cause such an event. Because so many 'failures' failed, the question is 'what was the initiating event.' You may be able to track it down using the 'freeze frame' stored in the OBD-II system. You will need a GOOD (Dealer or Good Indie Shop) to run the complete systems check.
Welcome to the era of 'dumb but very complicated' connected computer networks.
