SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: BUYING ADVICE - 1995 SL320
Old Aug 25, 2019 | 03:24 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Thoughts about this '95 SL please.
https://sacramento.craigslist.org/cto/d/elk-grove-mercedes-sl-320/6962583880.html
Car has only 115K miles, but obviously some issues as described by the seller.
Car also comes with Hardtop and storage rack.
As I have no experience with the SL Roadster, I would appreciate your thoughts and input. Is this a good deal for 750 bucks, needing some elbow grease and repairs?
Any thoughts about the extend of the issues and repairs?
I realize the 320 is not as desirable as the 500. However, this price seems low and hopefully worth the efforts?
Thanks very much in advance.
Old Aug 25, 2019 | 03:43 PM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
Smile
https://sacramento.craigslist.org/ct...962583880.html
Good price if body is in good shape the SL320 is a great car. But if all is original including wire harness head gasket and top cyls and you aint DIY and don't want to dump 6k and up, then I say run and don't look back. But as a good DIY project and you have some cash then I'd consider it. It does have fairly low miles for a M104 engine. My 94 SL320 started out that way 20k later I have a new condition SL320
Old Aug 25, 2019 | 06:33 PM
S70Houston's Avatar
Thanks very much FATHERTIME, greatly appreciate your input.
Can't say I do ALL DIY, but I certainly do some things DIY.
Some more input from you in regards to why you think the SL320 is a great car would be appreciated.
Got a pic of your 320 you could share?
Thanks again.
Old Aug 25, 2019 | 06:34 PM
S70Houston's Avatar
Got a pic of your SL320 you could share?
Thanks again.
Old Aug 25, 2019 | 07:21 PM
FATHERTIME's Avatar
Old Aug 25, 2019 | 07:33 PM
FATHERTIME's Avatar
Thanks again.
The motor is bullet proof it's the same chassis as the 500 but more nimble in the canyons where weight is a factor when entering corners, less under steer (push) I guess I can say it goes where you point it. Yes a little less in the power department of the 500 but all as much of a luxury roadster only difference is the engine. Plus the 500 at over 20 yrs will need the same maintenance. I can speak of this cause I own a 94 SL320, 98 SL500 and 99 SL600 and drive them all hard.
Old Aug 25, 2019 | 07:39 PM
FATHERTIME's Avatar
Restored 94 SL320
Old Aug 25, 2019 | 11:28 PM
S70Houston's Avatar
Thanks again, very informative.
Your SL looks great. Thanks for sharing.
Old Aug 26, 2019 | 11:45 AM
S70Houston's Avatar
Anyone else with some valuable input regarding this '95 SL320?
