SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: BeckwithR
Old Dec 22, 2019 | 11:08 PM
beckwithR's Avatar
W140 & W220
BeckwithR
I have several issues with two separate vehicles. I have a code P0410 which indicates that the ECM could be saying the 02 sensor is malfunctioning. It's listed as a Secondary Air Injection System Malfunction.This is on my 04 sl600 v12. I just replaced the ignition coil and now this code appears. I don't know if I broke or disturbed a vacuum line. All suggestions are appreciated. Where is the fuse located for the pump?
On my 98 sl500 I am getting code P0701 it says it relates to the MAF or the throttle body. Is there any video on how to remove and replace these two parts? I would like to clean them before I try anything else.
Old Dec 23, 2019 | 10:22 AM
mahunt's Avatar
1997 MB SL600
I'm super old, but I'll give this a stab.
Just Google what you want to do and when you find something that relates, watch it.
Old Dec 23, 2019 | 10:31 AM
beckwithR's Avatar
W140 & W220
Understand the google response. I have done that actually, I hadn't found one specific to my model. Do you know the location of the fuse for the pump on the V12.
Old Dec 23, 2019 | 02:14 PM
mahunt's Avatar
1997 MB SL600
Fuel pump?
In the trunk. Green block fuse.
Your avatar sez W140, so here you go.
I sure hope you are 60 or older.
