SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Looking for speed sensor
Old May 8, 2020 | 02:20 PM
Morsim's Avatar
1999 slk 230 blue
Hi everyone I'm desperately looking for Mercedes 1998 SL500 rear right ABS speed sensor part number A129 540 30 17 according to a few places the part is no longer available or discontinued my hope is someone here have a part car that has that part still in good working order. I found some information that says that Bosch 0 265 006 184 is the same part but to way confirm that is true my be someone here have a clue .Thanks
Old May 9, 2020 | 07:10 AM
Morsim's Avatar
1999 slk 230 blue
Rear right speed sensor
thanks for the suggestion but the part number 129 540 30 17 is what I got from the dealer so I'm sure its the right one and i did check with some sellers same results .....hoping to find it used some where.
Old May 18, 2020 | 12:52 PM
Morsim's Avatar
1999 slk 230 blue
rear speed sensor
Ok may be this will help someone in the future I may have found the problem with my rear right sensor issue there is a connector hidden below the cover inside the compartment behind the passenger seat it has all three sensors for the rear of the car left right and diff took the connectors out cleaned them and so far so good. So if you get these lights on for ABS SAR and your code is one of these sensors just give that connector a try first..
