SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: SL 600 1998
Old Nov 16, 2020 | 03:24 AM
ls S's Avatar
SL600
Post SL 600 1998
any one can help me why passenger side my sl 600 Air Flow (MAF) Sensor i replace twice some , everytime i replace airflow car drive okay but do not have power , engine light is on,
P1300 code , replace Camshaft Position Sensor ,still code is there, any one can give me idea ,what other thing i can do before taken back to mechanic shop
Thank You
Old Nov 16, 2020 | 08:18 AM
mahunt's Avatar
1997 MB SL600
Are you taking the car to a MB independent shop or MB dealership?
Both of these kinds of places specialize in MB repair and not just general car repair. If you are getting service from a repair shop that ALSO does MB service, that might not be good enough.
Both types of shops should easily be able to track down the source of your persistent problem, ESPECIALLY if it involves a CEL In addition to the code, MB repair manuals also provide a diagnostic flow chart to get to the root of an issue. This should be an easier ordeal for you.
Old Nov 16, 2020 | 11:23 AM
AndreasHannover's Avatar
SL600
P1300 CKP sensor circuit failure = crankshaft position sensor
Old Nov 16, 2020 | 04:00 PM
mahunt's Avatar
1997 MB SL600
Perhaps there was some confusion between a camshaft position sensor (both at the front of the engine, passenger side) and the crankshaft position sensor (both at the rear of the engine). In either case, change the sensors in pairs.
Old Nov 17, 2020 | 12:33 AM
sushipaste's Avatar
1999 SL600
you replaced wrong sensors then. Also after repairs, codes have to be cleared
Old Nov 19, 2020 | 01:33 AM
ls S's Avatar
SL600
its some mechanic , work for Mercedes service shop, but every take car to him, he has different idea about what is wrong with my car
Old Nov 19, 2020 | 01:35 AM
ls S's Avatar
SL600
no, just some guy , use to work at Mercedes
Old Nov 19, 2020 | 01:43 AM
ls S's Avatar
SL600
Thanks, you are right , (crankshaft position sensor ) , but how can get to it replace its end, they are back of engine, no way my small hand can get to it , any one can help , let me know how can re place it, or get me exact location of each one ,and temp sensor too, thank you guys
Old Nov 19, 2020 | 01:49 AM
ls S's Avatar
SL600
You are right the charge a lot but they fix car too,I use take my car always to dealer , for service . Since this coved , move to mountain , can find any mechanic work for on SL 600 22 years old,
Old Nov 19, 2020 | 08:41 AM
mahunt's Avatar
1997 MB SL600
Of all three of those sensors, the cam sensors are by far the easiest to replace. Pity.
The crankshaft sensor on the passenger side at the rear of the engine can be changed from above (I changed mine out without too much trouble).
It is easier to see and change the sensor if you remove the upper part of the false firewall first. Maybe that is the one that is bad. The second sensor on the driver side is much tougher to see and change as it is mostly sight unseen and gets replaced by touch from below. Do a Google search on V12 SL600 crankshaft position sensor change BenzWorld for a little more guidance. According to the law of evil, the driver's side sensor will be the one that is actually bad. It was in my case.
Both temp sensors (once again, 2 ECUs and each computer gets it's own sensor) are at the front of the engine under the front covers.
They are the brass sensors that screw into the water pump. The wiring harness snap fittings that plug into the sensors are usually brittle with age by now so you should get those as well. The hardest part about changing the sensor connectors is disengaging the wire ends, but it will be easy if the connectors are brittle, you just finish crunching them with pliers and harvest the fittings. Just remember to write down which wire goes where (positions 1-4) when you transfer over to the new connectors.
Let us know how it goes.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
