SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Rollbar lamp on and rollbar switch flashes (sometimes)
Old May 2, 2021 | 06:10 PM
MikeShields's Avatar
1991 Mercedes 300 SL
1991 300SL. About 50% of the time while driving the Rollbar warning lamp comes on and the rollbar switch lights flash.
Suggestions appreciated on checks, fixes or parts to replace.
Old May 2, 2021 | 08:07 PM
sushipaste's Avatar
1999 SL600
Battery if its old. Otherwise, you will need a STAR diagnostic scan
Old May 3, 2021 | 04:32 PM
Thanks, I will check electrical. For the 1991 I have an LED I can hookup to the plugs in the engine top left -- but by STAR diagnostic do you mean something more that I'd have to take into a dealership?
Old May 3, 2021 | 07:00 PM
Kebowers47's Avatar
001 s600, 94 sl600
there are numerous electrical systems involved in the top systems and each of them can be faulty. A good computer diagnosis will likely point to the faulty switch,connector, position sensor. There are position sensors everywhere and one of them is out of adjustment or you have a (mostly) broken wire.
Old May 6, 2021 | 12:30 PM
RScott's Avatar
S55, SL500, 500SL
Originally Posted by MikeShields
For the 1991 I have an LED I can hookup to the plugs in the engine top left...
Read/Erase and then read again the codes from "plug" #7. You can use your LED to count flashes, or you can look at the roll bar fault indicator. When you have the codes you look of their meaning in the diagnostic manual.
