SL/R129: Any broken sunvisor parts?
Driver's side R&R went well in the end, no issues there. Passenger side removal revealed that some gorilla had, in the past, broken the black plastic supporting bracket itself. The centering pin had been snapped off and badly glued back in, and the entire bracket had a sheen of dried adhesive suggesting it had been damaged as well.
So what I'm wondering is if someone has a passenger-side mounting block in good shape from an otherwise damaged/dead sunvisor? The pic isn't my part but it's the best close-up of the piece I'm referencing. I haven't found a standalone part number for it.
For now the mirror is attached with the two screws, and passengers are advised not to move it other than flipping it up and down since I don't want to torque the bracket. Reinstalling it required a third hand to press in the right way to get alignment with the second screw so the deformation on the black piece is enough to matter.
Many thanks!
