SL/R129: Replacement brake master cylinder for 97 SL600
It looks like the brake master cylinder on my 1997 SL600 is dying, and I need a replacement. The original part 0054307101 is NLA from MB. I have been unable to find any aftermarket sources for this part. Some online sellers list a TRW master cylinder as fitting the 1997 SL600, but this seems to be wrong because it is a replacement for a different master cylinder, part 0054308901. The main difference seems to be that mine has a flange on the right side (as seen from front of car) for mounting a brass-colored metal cube with a 2-pin electrical connector, that MB calls a brake valve. The other part, and the TRW one, don't seem to have this flange. There is a eBay seller from Germany selling what he calls a good used one for around USD$650. Is that really my best (or only) option?
Has anybody else been down this path and found a solution? Of course I searched the R129 forum (and the internet) on this topic but came up empty.
Tom
The extra valve is probably associated with the BAS function.
Flushing the brake system regularly has never been more important.
Am I right in thinking that to rebuild a master cylinder, you have to get a rebuild kit with new seals for it? So far I haven't seen any rebuild kits for these master cylinders offered anywhere.
Thanks for your reply,
Tom
Cheers
Tom
Tom
I read something about the function in the past, but forgot about it. I think it has something to do with the ESP. The functionality is probably explained in the Mercedes WIS. BTW: Ebay 235730277950
Cheers
Tom
They can be sleeved with stainless, reusing the original seals.
BAS (circa 199X, not today's BAS) senses the difference between your regular stopping brake pressure and when you panic stop. The idea of BAS is when in a panic situation the driver doesn't hit the brakes hard enough for a good short stop early enough. BAS provides extra braking pressure and the car stops quicker.
Fun fact: There is a service instruction from Mercedes to deactivate BAS on vehicles without ESP during inspection permantly. Since the 600 was always delivered with ESP, it is not listed as an optional extra. This sometimes leads to Mercedes workshops deactivating BAS on the V12 by mistake.
Mahunt, regarding rebuilding the master cylinder, I would have thought it's much like rebuilding a brake caliper in that you replace all the seals but the piston and bore usually good. So I'm surprised to read from you that this is not the case, that it's the cylinder bore that goes bad. But I'm certainly not an expert on this.
Cheers
Tom
Aluminum, like cast iron does react to the water absorbed in the brake fluid and can pit the bore surface. Both types of cylinders are also susceptible to galvanic corrosion due to dissimilar metals in the brake system just like the cooling system.
I think it might be easier to hone and rebuild a cast iron master cylinder, but that's why some folks rebuild with stainless steel and are done with it. It's just a final option to consider.
Good luck with your search and repair.
