SL/R129: 1992 SL500 dies while driving
I own a 92 SL500. Recently got fuel distributor and bosch caps replaced. Drove perfectly for a couple of days, then one time the engine died while driving. Starter cranks strong rpm goes up for a sec then engine dies and refuses to start again. Replaced battery, started like new, drove around and again it died. MAS module tested and works fine, alternator charge is fine. New fuel pumps , bosch accumolator, plugs..
any body had experienced the the same symptoms? Any ideas?
Thanks!
So idle control or ignition circuits.
So you need to first make a call on that before diving in.
I have 2 W201's. 88 and 89. The 89 daily used for 36 years and garaged in dry climate. Has no electrical gremlins whatsoever.
The new acquisition 88 with less miles lived in Portland and SF all its life and probably not garaged, I have cleaned out a lot of connectors for this one.
Just fixed the auto antenna connector corrosion with de-oxit. I also cleaned out the ECU connector as it was throwing CEL once is a while. One does not see the oxidation but it is there.
So it could be simple corrosion/oxidation of random stuff.
Also do not overlook the possibility of a an old OVP just cutting off randomly. I have had that in the '89. After months of chasing an intermittent shut-off while changing gears (manual tran) it turned out to be the OVP. I could write a chapter on why a car dies on an intermittent OVP. Later maybe....
If you have not replaced the OVP already, pull it out and check the date code on it and if over 10 years old just replace it with an MB one and keep the old one for later use.
MB and KAE are fine, all the rest are suspicious. URO ones are junk.
- Cheers!
- Cheers!
we finally located the problem. It was the EHA valve o ring! Changed it..car starts and drives perfectly.
Cheers
I assume you put it back together exactly how it came out? Or maybe you readjusted it? Would it not leak fuel if the o-ring was bad? Just asking questions as I do not have the answers.
there were no leaks, two cylinders were not getting fuel the way they should one was
getting too little and one too much. it did smell rich.
the question is, will this be the end of the random engine shut down or it only solved the "no start" issue... I guess time will tell..
so far the car is running smoothly
Hopefully the car was not run like that for long as that will ruin piston rings because the super rich cylinders get washed out and starved for much needed lubrication of the oil.
You probably have underlying FD issues too and should make sure the fueling is good and even under all engine driving conditions.
I would first check the Duty cycle at idle versus 2500rpm and make sure it does not vary too much (less than 10%).
And remember that the EHA current actually varies even more under load conditions in which case there is more demand for fuel if there is a fuel delivery issue from the injectors.
But again the cause of the random shutdown I suspect is something different.
