SL/R230: SL350 lowering option
S600,Sorry but 540i,740iL
the car being a SL350(R230, Asia model), came with factory AMG package, wheel, suspension(non-ABC) and muffer. Looking to lowering it just for look, any suggestion? The only available option I found is the H&R sport spring, anyone have experience of it compare to OEM AMG one? Thx!
You may not get much help here because this is a mainly US forum aside from people like me who keep bugging them and wont go away. The SL350 uses conventional suspension but the good news is that it might be easier to lower as a result. Be careful not to overdo it, you need to maintain the ground clearance.
SL500 2003 previous/ E350 2007 actually
ABC uses a cleverly designed suspension strut which changes its spring rate and damper characteristics using hydraulics, on the fly, based on what the car is doing. Lowering the car means changing what is a carefully designed system, although the ability to set the ride height is built in - the car lowers itself at speed and you can manually raise it in two stages.
With the SL350, the suspension structs are more conventional spring/damper struts and lowering the car is accomplished by more conventional component exchange.
You cant switch it off! It's a permanent system on the SL500+ and compared to how the older SL handle, it's a revelation. The ABC switch changes the parameters from "comfort" to "sport" and I agree there's not that much difference unless you are driving the car hard.
I lost the ABC once when it dumped its hydraulic fluid over the road, believe me, if the ABC quits, you know all about it. It's like driving on a trampoline.
SL500 and A-CLASS
Yes, it happened twice. The second time, the fluid was over my garage floor so I got them to pick the car up and truck it in.
The first time I took it in, they wouldn't let me take it away because it was unsafe and I had to find my own way home. That was why I made them come and pick the car up the second time.
The car was pretty much undriveable, bouncing around all over the place. There's no doubt the SL depends very heavily on its various hydraulic systems - suspension, brakes, steering, roof.
Leaks in the unions joining sections of pipework together. The first attempt to tighten them failed, the second time they replaced a section of the pipework.
SLK 200 Kompressor 2001; C180 1994
SL350 with ABC suspension
My dad ordered a SL350, and he chose to equip it with the optional ABC suspension (standard on SL500, SL600 and AMG versions). After driving a SL55 AMG, he was marvelled with it. I just hope that there are no fluid leaks, as mentioned in this Post.
