SL/R230: How much does the amg kit help with speed?
I like the look AMG package look. Some might disagree.
I believe the 05 SL 500 is a little faster than 6.1. A lot of those numbers are pre 7-speed automatic numbers. I think that when the 04 got the 7-speed, the numbers improved slightly.
If it is the SL55, then you are correct.
If it is some other package other than OEM then I have no idea.
If you want to make the car accelerate faster, you need to increase power and/or reduce weight or both, either of which will also reduce the ability of the car to put the power down on the road so, as SL65 owners will know, you would need to think about improving traction as well.
