SL/R230: Dyno - SL600
473 RWHP.
It was a rather hot day today, and we did it around 5:00pm, the hottest time of the day. He only had one fan at the front of the car, which I don't think helped that much. I will be curious to see the difference on a cooler day and with more fans.
I talked with another tuner, they said unimpressive, but then agian, it was in the high 80's and had inadequate air flow. I'd say you're doing pretty well.
Make sure you drive the car as much as you can for the ECU to learn to how you drive.
Have the other tuner post up some real world data, instead of a UNIMPRESSIVE comment.
As I was explaining to StephenK through msn, the E55 forum has priceless information on how they are trying to solve the heat issues. They are actually coming to the conclusion that performance modifications are useless at this point, because after about ten seconds of driving, the amount of heat basically constricts the efficency of the supercharger, therfore slowing the entire car down, rather than speeding it up!
You know what's really amazing about modifiying cars? Once you get over the whole 'it's not OEM' stigma, it's addicting.
Sometime next week I will be able to tell everyone what the real deal is with my car and the upgrade.
Being optimistic, look forward to some more impressive numbers.
I don't think exhaust would really matter that much, unless you're talking about before the turbos. But IIRC heat doesn't affect a turbocharged car as much as it would because the turbocharger still spools up, it just takes a tad bit longer to spool no?
All Mercedes cars are stringently engineered, I would doubt that heat of the parasitic and regular kind would have been overlooked.
Heat in the engine bay can be difficult to eradicate. Although the SL's engine bay is plenty big, finding vents and other heat dissipation methods can be difficult when the occupier happens to be a 5.5L Twin-Turbo V12.
Vraa, turbo's are capable of spinning much, much higher than superchargers, the speed at which they can spool is dependent upon the size of the engine (more cylinders means more exhaust
) and the size of the turbocharger. Mercedes has used small turbochargers, which have a limit of 580hp, with a specific aim of providing immense low-down torque, smaller turbo's spool quicker.
After the upgrade it made 522hp at the rear wheels or 635hp at the flywheel.
However, not to make bad remarks about tuners, the info that I got about the limit of the turbochargers came from Brabus. Now I'm not one for tuning, and Brabus' upgardes are extortionate, but their most powerful kit for the S600 ECU is up to 570-580hp. Anything more and they have to increase engine displacement and modify turbochargers.
There's this knowledge and then there's Ben Treynor's real-life example... :o
Regardless, it does prove one thing once and for all, mechanically, Mercedes' cars are built with an astounding amount of component redundancy.
