SL/R230: Sat Nav - Turn off Helga?
Old Jan 28, 2006 | 02:48 AM
uk1's Avatar
uk1
04 SL500
Once a journey has been set and calculated, I cannot work out how to keep the map going but turn the voice commands off - so I can listen to the music uninterrupted.
Is this possible please?
SL500 03
Jeff
Old Jan 28, 2006 | 09:14 AM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Mute
When you hear navigation instructions press the mute button and then you shouldn't hear it again. You can always press repeat if you miss the instruction and press mute as soon as you hear it.
Old Jan 28, 2006 | 09:19 AM
wings's Avatar
And there will be no music!
Old Jan 28, 2006 | 09:20 AM
StephenK's Avatar
Wrong
WRONG, it will mute the navigation instructions only.
Old Jan 28, 2006 | 11:53 AM
uk1's Avatar
uk1
04 SL500
Thanks for that - appreciate it. However, when I tried that it did mute the music.
Jeff
Old Jan 28, 2006 | 12:21 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Jeff
You have to hit mute when the NAV voice is speaking. If you hit mute without the nav speaking it will mute the music. On the old models if you hit and hold mute while the nav is speaking it will mute for the whole trip and you will see a message on the screen that says that voice output has been muted. Try this and see if it works.
Old Jan 28, 2006 | 12:48 PM
uk1's Avatar
uk1
04 SL500
Thanks John, I'll try it.
