SL/R230: Changing Rear Taillights
2006 SL600, 2001 S500, 1996 SL320
Does anyone know how simple or complicated it is to change the rear taillights on the SL. I hear several people talking about changing to the 07 style.
2004 SL55AMG, Alabaster White
Changing to 07 style
Originally Posted by ////papa55
My friend changed his R230's taillights and high mount stop lump to 07 style. It seems simple even though I don't know the detail.
Detail ...
Followings are the only detal that I heard from my friend.
Parts number
07y R230 AMG Taillamp
A 230 820 15 64 (L)
A 230 820 16 64 (R)
07y R230 AMG Highmount stoplamp
A 230 820 07 56
Please give me a time to ask him more details. His car is 03 SL55AMG and he could changed his tail lamps and they are working.
Sorry but I did not change my 04 SL55AMG's tail lamps.
Parts number
A 230 820 15 64 (L)
A 230 820 16 64 (R)
A 230 820 07 56
The tail lamps are totally interchangable. Any model lamp will work on any R230 model.
The process of changing them takes about 1.5 hours and like anything is not very hard if you know what you are doing but can be a challange if you don't.
If you do it properly, it takes some knowledge to get it done. If you are like some and don't mind bending the inside panels just a little, it is a much easier task.
I have done them three times. Once the easy way and twice the right way.
Originally Posted by RedMongoosE
took about 45min to change the tail lights on my 129. it cant be that much harder....
Mark
Mark
The center part has some tricky pieces to take off and put back if you don't want to crack them. All in all, not hard if you know what you are doing but it does take some handling of most of the trunk panels.
The center brake panel requires you take off the panel underneath the trunk and that too requires some time if you don't want to break the little plastic parts that hold the panel to the underside. There are about 9 of them and they do break if not pulled off in the correct direction.
The center brake light is easy to change, just make sure you have the top down when you do it. Care is needed when removing the carpeted panel, you can easily break the plastic pins.
Two 10mm bolts hold the light in.... took me thirty minutes to change them.
As far as the tail lamps, it will take about an hour or so to change them.
