SL/R230: Temperature Gauge and Idling questions.....
On the 2003 SL500 where does most peoples Temperature gauges at? The ones I see are usually a little higher than middle and fluctuates depending on climate and how the car is driven. It goes up and than goes back down to around middle of the gauge. Not often but I have seen them do that? If its not normal could it just need a coolant flush? Maybe a new Water Pump or thermastat? Or is a little fluctation normal? Also the Idles is at about 1k RPM at idle sometimes a tad bit higher. Shouldnt that be lower or are these how the cars are?
Thanks for the info and help.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
That would be great. Im finalizing a deal and noticed that the temp fluctuates. It is above normal but when Im driving it will go back down. During traffic it climbs back up again but havent seen it go to the top.
As for the RPM I thought it would be at a few hundred RPM as well but the guy is telling me with these cars the idles are all above the 1000 RPM mark. I found that interesting. But like I said Im new with the SL's.
But I would really appriciate it if you can let me know when you get back in your car on Monday.
I was digging through old photos I've taken.
My friends ask my why I take so many photos. I always respond for memories and just in case![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](http://img168.imageshack.us/img168/5329/dsc01907xq0.jpg)
Car is in park I believe right after start. That's why the temp gauge is almost nada.
To be quite honest, I don't know about the 2003, but that seriously does not sound right. My 2005 doesn't have the temp flucuating during a drive, and it certainly doesn't idle (after being warmed up) above 1k rpm. I would have a dealership give you a full evaluation before signing the dotted line....
Im meeting up with him again tomorrow so Im going to double check the Idle I believe it was above 10 but now that I think about it, it may have just been over the other marking below the 10 on the RPM. Im assuming if thats the case its normal. Anything above 10 which Im assuming is 1000 RPM is not normal?
As for the ideling Ill double check that but I believe it is above 10 but I could be wrong. Isnt there a valve screw on the throttle body that I could adjust? I believe most cars have that for adjustment?
I went and took a look at the car today and double checked the idle and it is where it supposed to be. I dont know what the hell I was thinking. I drove it around and the temp doesnt fluctuate as much this time around but I didnt drive it around to long or in traffic but I just want to be safe and want to know what the problem could be? Could it just need a coolant flush? Maybe a new water pump or thermastat? Any help would be great.
I am going to take it in for Service A since it is due and was going to have them check everything throughly but I was also thinking of finalizing everything tomorrow.
Enterprise rent-a-car!!!
since 1998 temp gaugels on MB's do not reflect actual engine tempreture unless engine is over 115 degrees.
Gauge is coded to 95 degrees once operation temp hase been achieved.
This is to stop everyone in hot areas bringing there car into the shop in the summer saying its running hotter than it was, no needle fluctuations.
Engine control monitors actual temp and runs fans,aux fans as required, and controls the gauge!!
Thanks for all the help guys!!
Sorry for the late reply, dads had the SL for the week + I got a ticket (
The rpm's at idle in drive are a hair above 500rpm.
Temperature gauge is above 80 and dips up and down a bit.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Okay I have noticed the dips up and down so thats good to know its normal. As for the idle its normal. I was just tripping out on things and must have just freaked a bit and saw things. But it is normal. Thanks for the heads up.
