SL/R230: Does the sl have a recall on the abc like the cl does?
If your friend has an issue w/ the ABC component, and he has an extended warranty, it should be fixed since ABC is part of the shocks/suspension sub-system in a car. Unless it's clearly excluded from the warranty, it should be covered.
Not sure why your friend's entire braking system got replaced. If the car was in the shop for the SBC recall, the fix is the following:
DEALERS WILL INSTALL A BRACKET AND REPLACEMENT GROUND WIRE TO THE SBC PUMP UNIT ON ALL VEHICLES FREE OF CHARGE. ADDITIONALLY DEALERS WILL INSPECT AND REPLACE THE SBC PUMP UNIT IN SL VEHICLES PRODUCED DURING A LIMITED PRODUCTION PERIOD. THE RECALL BEGAN ON AUGUST 8, 2005. OWNERS MAY CONTACT MERCEDES-BENZ AT 1-800-367-6372
Also, MBUSA should have mailed your friend a letter stating the SBC Pump is under warranty for 10 years from the date of manufacture of the car.
