SL/R230: Under dash 12volt supply needed for V1 install
Steel Grey 2012 ML350 is wife's
Accessing underneith the cigarette lighter plug via disassembly of the center console would be ideal.
I just removed and documented (DIY) the center console on the P3 forum. Even made pictures of each step .....
The lighter plug is real easy to tap into ......
checkout the writeup
www . pointed three . com (remove the spaces)
new magazine, 0 to 60
My man hooked my V1 into the fuse box under the hood up by the firewall, he found a good draw on a fuse with no apparent usage, so far so good.
ps: get the concealed display, not expensive and sits right there in front on the ledge by the temp gauge, barely turn ur head to look.
ps2: boys and girls, check out a brand new publication, impressive, cald.....
"0-60"
(as in, zero to sixty mph, premiere issue, fall2007, red viper hood on cover)
"0-60"
