SL/R230: Breaks Screech like crazy!!
2013 SL 550
Does anyone have this problem? My breaks screech all the time! I have an SL 550 w/AMG package. My CLK never did this, and I was told by the dealer that it is break dust, I cleaned out the wheels and the screeching seems to go away, but for only 3-4 days, then it's back once again and it's quite bad. My boss has a brand new CLS 550 and his car does the same thing.
I was told by a friend in the mechanic business that the break pads are soft and provide better stopping power, however they build up more break dust causing the screeching sound. Someone else told me to get Porsche break pads when these go and the problem will go away.
Any suggestions? Help is greatly appreciated!!!
C63S coupe, X5M
I've taken my car in 3 times to get rid of it, they failed each and every time. In fact, the last time I took it in they made it worse even though they replaced the pads and rotors (or so they say). Fletcher Jones suck.
I just don't have the time to deal with it anymore, engine braking helps...![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Good luck.
Good luck.
I endure the same brake squeal from time to time. Seems to be better after I wash brake dust from the wheels. I spray water into the calipers to remove as much dust as possible.
From what I understand, it is common due to the brake dust.
a word to the wise
You're going to hate me, but my car's brakes work perfectly with no noticeable sounds at all. I have to admit I babied it for the first 3,000 miles and set them in nicely, this may have something to do with it. In general the harder you drive a car the more time you'll spend in MBs waiting room. Of course they may not bother mentioning this since their under-qualified-just-out-of-high-school help need new cars to practice on!
I agree there is a lot of dust coming out of there, not to mention the black soot I constantly find on my rear bumper after just 100 miles, Chri$t, when is this going to stop! It shows readily on white cars, just run your finger over the back bumper and you'll see what I mean, yuck. Have I got to live with this forever?
Never wash your SL and leave it wet back there and drive off, otherwise the exhaust dust will become practically glued on.
1 Post
SL500, GL550, Escalade, 66 Corvette
I do the same thing but add one more step: I first use an air compressor and spray air into the calipers. It seems to get the dust out, but makes a mess. I do this BEFORE I wash it. It really cleans out the brake dust for maybe a week to 10 days before the noise comes back.
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
You may need to bed them in a bit, but if you switch to Porterfield R4S compound, you will have less noise and no brake dust.
2007 SL550
Mine started squeeking about 3 weeks after I got it and I thought I was going to have to take it to the dealer to have it checked. But being the procrastinator that I am, I put it off and put it off. After about another month, they stopped squeeking on their own. They have been perfectly quiet since then. Not sure if that would be the case for everyone, but mine are fine now.
07 ML63 Silver Dead at 85k, 14 RS5, 05 SL600
Mine (SL) only squeak when cold or babying the car. Run it up and stomp on the brakes hard a few times - no more squeak! After a sedate city drive in the ML the rotors are not even hot. They need a lot of work to heat up.
CL500 216
The reason that the brakes squeak is due to resonance of the pads.
The correct cure is to apply the special grease to the piston faces in the caliper and to the metal shim plate.
The never squeak when the pads are installed correctly
1 Post
06 SV650S, 11 Santa Fe
2002 C230 coupe , NOt THE AVATAR!!
C63S coupe, X5M
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
I hope you've had it fixed, haha.
