SL/R230: central console removal-comand
Old Jan 6, 2008 | 06:11 PM
porto's Avatar
mercedes sl 350 from 2003
hello everybody
need to fix laser disk from comand on my SL R230.
I UNDERSTAND CENTRAL CONSOLE MUST BE REMOVED.
Any clues /photos for this job?
THANKS
Old Jan 6, 2008 | 10:36 PM
alexx's Avatar
2003 SL500
Center Console Removal
Originally Posted by porto
hello everybody
THANKS
Try going to www.pointedthree.com and check R230 Class for thread by
pleubner dated 8/30/07 called Center Console and Ashtray Removal (How To)
Old Jan 7, 2008 | 12:41 AM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
I have a cd
I have a cd, that has a video showing the removal of the command unit, I will try to post it tomorrow when I get back from the coast.
Old Jan 7, 2008 | 12:48 PM
XJ9's Avatar
XJ9
C350
hello everybody
THANKS
the quickie answer is to first pull the two side panels on the console; these will pry right out starting at middle seam (right about at the seatbelt reciever). once out it exposes several T-20 screws. unscrew 3 on each side. there are more than three on each side but the ones you want are ~20 mm long. (the furthest back set of screws are set in and not easy to see. use a flashlight to find them.). once out the console top piece ( the wood panel) comes out as one piece. begin by prying at the rear and working forward. reach underneath as you go along and disconnect the cables
Old Jan 7, 2008 | 01:41 PM
gocargo's Avatar
Steel Grey 2012 ML350 is wife's
Here's a link with detailed instructions and fotos.. although you must create a simple account before viewing the pictures. http://www.pointedthree.com/disc/for...sts=21&start=1
Old Jan 9, 2008 | 06:34 PM
porto's Avatar
Hi
Thanks A Lot.
Regards From Portugal!!!!
Old Jan 9, 2008 | 06:41 PM
porto's Avatar
But, Guys, The Comand Must Be Removed!
How?
Thanks Again!
Old Jan 11, 2008 | 10:16 AM
gocargo's Avatar
If all else fails..
Old Jan 11, 2008 | 11:56 AM
JackStraw's Avatar
2005 SL600, 2011 Honda Odyssey Touring Elite
How?
Thanks Again!
Why do you want to do this yourself?
Old Jan 11, 2008 | 03:15 PM
porto's Avatar
Originally Posted by gocargo
If all else fails..
I´M ALMOST THERE......
Old Jan 11, 2008 | 03:19 PM
porto's Avatar
THE LOCAL MB DEALER CHARGES....USD2.500 !!! FOR THE JOB!!!!!!!!
(the laser disk core is .....USD 150!!!!!!!!!!!!!!)
NOW YOU KNOW!
Old Jan 11, 2008 | 03:21 PM
porto's Avatar
PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!
