SL/R230: Strange noise when I cold start...please advise
Old Feb 5, 2008 | 04:40 AM
CY's Avatar
CY
SL/M6
Lately when I cold start my SL, for the frst minute or so it sounds like a belt or something under the hood is rattling (like tin can noises if that makes sense at all). I also hear a bit of a strange whistling. Both go away within a minute. I took it to the dealer but of course it wouldnt replicate the noises for them. Should I be worried enough to leave it there over night? Anyone else ever have this issue?
Thanks,
Cy
Old Feb 5, 2008 | 01:18 PM
bltserv's Avatar
2005 SL55, 2000 CL500
Thats Normal.
Its the suspension charging it self up when you open the door.
Car will do this if it has sat for a few days.
Dont worry about it.
Old Feb 5, 2008 | 06:46 PM
CY's Avatar
CY
SL/M6
Really? That could be one of the noises but the other one sounds like a loose tensioner or something...like a rock in a tin can.
Old Feb 6, 2008 | 01:33 PM
bltserv's Avatar
Mine sounds like a compressor coming online.
If your not used to it it would sound like something wrong.
This is before I turn the key.
After starting the car. It cycles and it does sound a bit "Belty" until it warms.
But mine has the Super Charger unit to add to the warm up process.
But its not "Rock in a Can" ???
If its a metallic sound then time to somehow record it or get it
to do this behavior at the dealer.
Good Luck.....
Old Feb 6, 2008 | 08:12 PM
CY's Avatar
CY
SL/M6
Thanks for your help...My lease comes up in 55 days or so....hope it doesnt bust by then.
Old Feb 6, 2008 | 10:40 PM
JackStraw's Avatar
2005 SL600, 2011 Honda Odyssey Touring Elite
Take it to the shop and leave it over night.
Old Feb 7, 2008 | 05:00 AM
Aviator's Avatar
Thanks,
Cy
May be a cracked ceramic in the CAT converter. As it warms up the rattle is gone.
Old Feb 9, 2008 | 01:02 AM
lovemysl's Avatar
SL500 2003 Designo (sold), SL500 2004, Nissan GT350
Maybe its the fuel pump kicking on.
Old Feb 9, 2008 | 01:12 AM
CY's Avatar
CY
SL/M6
It also seems to squeal a bit at the same moment like an air leak or something....it all goes away in a few minutes and the car drives like usual. I am probably going to take it in but Id hate to have a C rental for the last weeks of my lease.
Old Feb 13, 2008 | 07:22 PM
jooooby1's Avatar
SL55
Very common problem on older SLs. Most likely the bearings. Easy and cheap to replace. Should also replace pulley at the same time.
Old Feb 18, 2008 | 12:34 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
What "bearings"? Need more info...
as my 05 makes similar noises. I also think it's coming from the compressor...but is less noisy with it on than off.
