SL/R230: Brake pump failure?
jeff
Sensotronic was first released on the SL500's.. I hate to say it, but that's the risk you take when you buy a first year car.
Hopefully MBUSA will resolve the problem. Remember, if it fails one more time, you can lemon law it.
Generally, replacing the same item more than once is a sign of desparation and total ignorance. If they replace an item and there is no change, their initial diagnosis is wrong so they must look elsewhere. The dealer is clutching at straws.
Faults this early in a car's life can often be silly things like the wires not properly inserted into a connector, or a connector not properly seated, or a blown fuse.
If I were you, I'd pick up the phone and make a lot of noise directly to MB corporate customer services and tell them you want some action. Remember the plant should be able to dial into your car to diagnose problems when hooked up at the dealer. If your dealer is not up to it, find one who is.
Keep us posted!
Certainly wish you luck in getting it resolved. The SL has been around for more than a year now with something like 15-20000 cars produced so the new technology is well bedded in. Sounds like you have a rogue failure.
As for the diagnosis, the computer they plug in should be able to diagnose to the failing component level but it has to have the proper level of diagnostic software on it.
I think you need to start making lots of noise to get it resolved....
jeff
jeff
