SL/R230: What size tires?
Old Jun 30, 2008 | 11:40 AM
metalica_23's Avatar
'06 SL600
What size tires?
I really like some of the pics I see out there with the 20" chrome rims.
1.) Can anyone provide me with some specs and costs for what they got?
2.) What size tires can I realisitcally get on the rear? I've seen a couple for sale with 305s on the back. Is that realistic/easy to do? i.e., I don't want to have the installer do anything special to get the rears on, and obviously wouldn't want them to rub in any fashion...
Thanks!
Rodney
Old Jun 30, 2008 | 05:24 PM
Keng1's Avatar
2008 M6 Vert
If you do a search, you'll find a wealth of information.
I have 20" Chromed Brabus rims on mine. 305 in the rear and 255s in the front. No fitting issues with the car or special adjustmets made.
Old Jun 30, 2008 | 06:14 PM
Sunir's Avatar
SL55 AMG
you can fit 305's without issue as mentioned about. I went with 19"s due to city terrain which I on the rare occasion have to go through for meetings for work etc. The trick is tire sidewall and wheel offset. I use a 285/30-19 rear and a 245/35-19 which I think is a good setup for the car in terms of unsprung tire weight, contact patch, looks, and performance.
Old Jun 30, 2008 | 07:19 PM
'06 SL600
I'll definitely have to do some more research. I live in MA and the roads here can be brutal, I've dented two rims on my e55, and those 18s aren't nearly as bad as 20s. I should probably realistically consider 19s. I just really like the look of those super wide tires in the rear...
Old Jun 30, 2008 | 08:33 PM
Alex@wheelexperts's Avatar
07 S550 & 08 335i
305s in the rear isnt a problem at all. They fit perfectly. Only if you have the proper wheel/offset
PM me if you have any questions. I would be glad to help...
