SL/R230: small accident, big problem...
Old Aug 21, 2008 | 09:10 AM
khaz3al's Avatar
2005 vw touareg, sl500 r129 SOLD, 2002 sl500 kleemann
hi all, i had a small accident with m sl 500
i hit a car infront of me, but not much damage was done or so it seemed...
i think my roll over bar popped up when i hit, and now it doesnt go down.
what do i need to make this work?
i went to the dealer, he told me it will take around 60 KD to check, and 100 kd for parts.... do i even need parts? isnt it some kind of lock on the computer?
what should i do? does anyone know how to fix this, or did it happen to anyone?
tnx in advance
hussain
Old Aug 21, 2008 | 10:50 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
If the roll bar automatically deploys, then you have to reset it before it can be lowered. To do this, press the roll bar raise button for a few seconds until you hear a "click". Then you can press the lower button to lower the bar.
Old Aug 21, 2008 | 02:01 PM
bltserv's Avatar
2005 SL55, 2000 CL500
That worked for mine when I got rear ended in February and it popped up on its own. Good Luck.
Old Aug 21, 2008 | 05:28 PM
R230_Nicke's Avatar
SL 600 640bhp/1000Nm
tnx in advance
hussain
If thats what Your dealer told You, I'm telling You: Change dealer.
They dont have a clue what they are talking about.
All You have to do is what people before suggested.
I had to do it a couple of times when I have been drifting with my car..
I even think its in the manual if You or the MB people care to read it.
/ Nicke
Old Aug 22, 2008 | 12:13 AM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Mine Deployed Once
Mine Deployed Once and that is what the service advisor told me to do too. Simple.
Old Aug 22, 2008 | 12:14 PM
khaz3al's Avatar
i tried it, it wont work, i hear the click, then when i push the "down" button it wont go down
i have a smartop controller should i disable it first?
might it be a problem?
Old Aug 24, 2008 | 12:40 AM
StephenK's Avatar
What
What is a smart top controller?
Old Aug 24, 2008 | 11:51 AM
khaz3al's Avatar
its a "chip" u install wich controls the roof in various ways, like open it while moving, or one touch open/close and stuff like that.
Old Aug 25, 2008 | 07:08 PM
MB Fanatic's Avatar
4 wheels
Yes remove this smart chip controller. This procedure works on my SL as well.
Old Aug 26, 2008 | 04:08 AM
khaz3al's Avatar
do i have to completly unplug it or just trun it off from the settings??
i switched it off from the settings and it didnt work. i might go for the dealers it my only choice, getting ROBBED!!
Old Aug 26, 2008 | 12:59 PM
Keng1's Avatar
2008 M6 Vert
Did you try lowering the top? I did that after a small fender bender and it worked for me.
Old Aug 26, 2008 | 02:28 PM
khaz3al's Avatar
what do u mean by lowered the top if u mean that to open the top it won't open if the roll bar is raised and i want to know if anyone had a smart=top moduular and the same problem as mine and i want to know if i need to unplugg it completely to reset the roll bar ii do i just need to turn it off ??
tnx in advance
Old Sep 8, 2008 | 01:23 PM
khaz3al's Avatar
so, in the end i finally desided to go the dealers, charged me 41kd to fix it and they did it, i personally tried EVERYTHING but i was fed up..... so thanx for all the input guys it helped!!
khaz3al
