SL/R230: What is this on this CAR being detailed?
Old Dec 11, 2008 | 01:07 AM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
https://mbworld.org/forums/detailing...jet-black.html
In the first photo, what are they using?
Old Dec 11, 2008 | 02:20 AM
MB Fanatic's Avatar
4 wheels
I don't know but I would pay that guy some serious dough to clean the SL63.
Old Dec 11, 2008 | 09:40 AM
Television's Avatar
CL500 216
Its a paint thickness gauge so he knows how much to rub off
Old Dec 11, 2008 | 09:43 AM
Acez's Avatar
2001 Kleemann CLK 230K, 2006 CLS 350, GTR R35
i believe he said first photo, so its a foam cannon. second picture is the paint thickness gauge.
Old Dec 11, 2008 | 10:42 AM
sleewell's Avatar
2011 E350 4matic
basically a foaming gun, you just attach to the hose and insert soap. looks like it works well, i wonder if you still have to use a little elbow grease with a microfiber sponge pad after the foam is sprayed on. maybe Greg will help us...
http://www.detailedimage.com/Gilmour...Foam-Gun-P210/
Old Dec 11, 2008 | 11:21 AM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
It is a foam gun. I use one on my cars and it works quite well (one of the cars is black). What it does is to lubricate and lift off the "dirt" on the surface and helps to reduce scratching of the paint. I use a special soap that I cannot recall the name at this time that helps to create the foam. The stuff puts out a thick foam that is quite slippery but you still have to go over the surface with a wash mit. I still use the 2 bucket method even with the foam gun.
In my estimation it is well worth it if you are a perfectionist.
Old Dec 11, 2008 | 11:57 AM
2MnyToys's Avatar
2004 SL55
The way the foam is sticking in the picture it looks more like a foam cannon was used than a foam gun. Basically the difference is that a foam cannon is used with a pressure washer and the foam almost has the consistency if shaving cream. Here's a video (really bad music): http://www.youtube.com/watch?v=phR_nyDwxvQ I know it says foam gun but it's a cannon. Here's a great thread at autopia.com http://www.autopia.org/forum/car-det...-much-fun.html
