SL/R230: How do you know if you have Bi Xenon
Old Dec 22, 2008 | 11:03 PM
Robertpel99's Avatar
2003 and 1998 E320
I have a 2005 SL500 and the window sticker says the bi Xenon was added for $745. Looking at the lights i dont think so, the low beam is a large projector that emits a blue light. The high beam looks like a regular yellow beam of light.
Am i missing something here. If it has it doesnt that mean both should be blue light in nature
Old Dec 28, 2008 | 11:01 PM
gqa's Avatar
gqa
05' sl 500
bi-xenon just means you have a movable reflecting shield the moves to reflect the low beams to a higher and wider beam. basically it just uses the same bulb so yes you should see the xenon color whether you have it on hi or lo beam.
Old Dec 28, 2008 | 11:05 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Is that the way you see it on your 500?
Old Dec 28, 2008 | 11:08 PM
gqa's Avatar
gqa
05' sl 500
well why don't you test yours if you have bi-xenon. i have and i have also changed out my bulbs personally so i know there is only 1 xenon bulb for both beams.
Old Dec 28, 2008 | 11:23 PM
StephenK's Avatar
and
and on your original bulb it looked the same between low and high beem?
Old Dec 28, 2008 | 11:44 PM
gqa's Avatar
gqa
05' sl 500
no thats not what i said. when you pull the stick for the high beams the shield moves producing a seemingly brighter light. it does look different when you change it from back and forth but the color is still the same. that's what the OP was asking whether the high beams should have the same color(xenon) as the low beams on a sl with the bi-xenon option.
i was suspicious when some other member told me this as well until i actually tested it. have someone else switch back and forth the lo and hi beams and watch what happens
Old Dec 28, 2008 | 11:47 PM
StephenK's Avatar
Mine
Mine are TOTALLY different, low beam nice whitish bright light, high beams are bright but more yellowish tint.
Old Dec 29, 2008 | 12:27 AM
gqa's Avatar
gqa
05' sl 500
do you have the bi-xenon option? i sounds like you don't. sl's without bi-xenons use a regular halogen bulb (yellowish color)for high beams
Old Dec 29, 2008 | 12:29 AM
StephenK's Avatar
I guess
I guess I don't have it, since it comes standard on SL600's.
Old Dec 29, 2008 | 12:58 AM
gqa's Avatar
gqa
05' sl 500
i went out to re-check my hi and low beams since your trying to make me look foolish rather than help the op out. did you check yours?
this it what actually happens. when you turn your hi beams on, on sl's equipped with bi-xenons, the same lo beam lights are shifted to a higher beam pattern via the shield i mentioned in the above posts and a halogen light comes on next to your xenon bulb (in the same area as your parking lamps) but your same low beam xenons are still on but at a higher pattern. you can test this by covering all of your lights except for 1 headlight and you will see your low beam xenon move higher up on an object such as a wall in front of you.
try testing this out before you post back and tell me what you find
Old Dec 29, 2008 | 08:25 PM
StephenK's Avatar
Check this out
http://www.youtube.com/watch?v=92bqy...e=channel_page
Old Dec 29, 2008 | 09:25 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
WOW!!!!!! can't get better help than that nice video man !!!!
Old Dec 30, 2008 | 01:09 AM
Kar don's Avatar
Mercedes-Benz
for me its hard to tell what is going on in that video but since I know what happens its hard for me to pretend. I'll sum it up here.
Bi-xenon equipped:
Low beam - bluish white xenon light
High beam - Xenon projector has a shutter that moves and illuminates further down the road, also the halgoen inner high beams also illuminate for extra light.
Non-bixenon equipped:
Low beam- bluish white xenon light
High beam - Xenon low beam and halgoen high beam. No shutter in low beam to expose more high intensity xenon light.
Old Dec 30, 2008 | 10:58 AM
2003 and 1998 E320
I have bi xenon and i find it comical they can get away with charging almost 800 bucks for a simple shutter mechanism
Old Dec 30, 2008 | 11:47 AM
gqa's Avatar
gqa
05' sl 500
Bi-xenon equipped:
thanks, maybe i didn't explain myself as good as you did.
Old Dec 30, 2008 | 02:31 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
If you call your dealer and give them your VIN and they can tell you for sure.
You can also try putting your VIN at this site. http://old.mbclub.ru/mb/vin/view.html
Old Jan 14, 2009 | 11:41 AM
mikeinsf's Avatar
SL500
Better link for the VIN Lookup:
http://old.mbclub.ru/mb/vin/?lng=eng
