SL/R230: LOWERING LINKS ?
Old Nov 7, 2010 | 05:35 PM
  #326
AdrockTT's Avatar
SL65
You can adjust the links to any height you want. Obviously if you slam the car so low it will barely drive, you'll have excessive camber/outer tire wear, rub over bumps, and every other known issue related to being too low (including a dash error of car too low). A more reasonable (yet lowered) ride height with alignment at the final height should minimize any issues.
My 2 cents
Old Nov 8, 2010 | 04:31 PM
  #327
traumadoc's Avatar
2022 AMG SL 63. 2021 APR stage 1 Audi SQ7.
Thank you
I just ordered them and install likely Friday. We shall see.
Old Nov 23, 2010 | 11:20 PM
  #328
biophase's Avatar
03 SL500
Anyone else have their lowered car seem to raise after time goes by. When I first lowered it I had probably <1" tire clearance. Now it's about 1.5". It seems like my car is now higher than it was before after a year.
Old Nov 23, 2010 | 11:49 PM
  #329
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Really , my S500 Is lowered but haven't gone up since the drop .
Old Nov 24, 2010 | 12:16 AM
  #330
traumadoc's Avatar
How long has it been?
Mine could use a slight rise anyway
Old Nov 29, 2010 | 08:43 PM
  #331
MBSL4me's Avatar
99 Corvette (heavily modded), 2018 Sonata Sport, 2016 Silverado 2500HD LTZ, 62 Nova Pro Street
I've already done the wheels and am not sure if I can use the lowering links as the front aftermarket wheels I put on are .7 of an inch taller than the stock wheels/tires. If you feel your hand on the inside of the tire at the top of the front wheels, there's only about 3/8 inch clearance from the end of the suspension bolt to my tire as it is.
Does anyone know if the links would affect this gap or would the clearance on the suspension bolt be maintained if I used the links to lower it another 1/2 inch or so?
By the way, my tire sizes are 245/40/19 on front (and 285/35/19 on back).
Jon
Old Dec 20, 2010 | 01:00 PM
  #332
Late's Avatar
03 SL500(Sold), 09 C300, 11 E550
Brought the 500 into the dealer to get an alignment done today and they told me that it could not be properly aligned because the car is too low? I didn't drop it all that much but they are saying that there is a beam that needs to go under the car that apparently wont fit?
anyone had this issue?
Old Dec 20, 2010 | 01:01 PM
  #333
m4xm1l10n's Avatar
Course they will tell you that No worries man I am going on 15K no tire wear issue .
Old Jan 2, 2011 | 03:26 AM
  #334
neomonkey's Avatar
SL500
Once you lower it you can't get the camber correct and your tires will wear out fast.
m4xm1l10n, when you check your tire wear be sure to check the inner tire corners, not the threads. Mine had so much thread left, but when you got it on the lift you could see the inside corners of the tire wearing down to the belts.
I made the mistake of only checking the thread on the inside most thread thinking everything was fine. Turn your wheel facing outward and get under the car and look at the inside walls.
I have some rubbing on my wheel wells, but I'm not sure how it's rubbing. I put a mark on my wheel well with black marker and I can see it getting rubbed off very slowly, like over the course of a year. Maybe its just road grime constantly hitting it??
Old Apr 21, 2011 | 05:09 PM
  #335
isseygino's Avatar
SL 500
how much does it cost for installation?
Old Apr 22, 2011 | 03:41 PM
  #336
Late's Avatar
Yea i can attest to this. I've had 2 blowouts from inner tread wearing down to the chords. I'm running 19 inch Potenza's (supposed to have good tread life) so i might not keep the keep the car lowered... New tires on the car 4k miles ago and the rears are almost bald again on the inner tread.
So can anyone confirm that there is no way that the camber can be adjusted? not even by the dealer?
Old May 24, 2011 | 03:53 AM
  #337
drivebenz's Avatar
1971 300SEL 6.3 #4789, 1991 560SEL, 1999 CL600, 2003 S500, 2005 SL500
Help needed
I installed the links on my sl 500 (with 19" wheels) and there is a 1/2" difference in height on the passenger side (higher than driver's side). This 1/2" height difference in on either the front wheel or back wheel. It changes from time to time after I raise the vehicle and re-lower it. For example today the front heights matches but the in the rear I have a 1/2" difference in height. yesterday it was the other way around.
Any ideas how to fix this problem?
Steve
Old Jun 3, 2011 | 04:51 PM
  #338
gyzmo123's Avatar
2013 SL550 Tectite Black
I was thinking of lowering my car a bit; Anyone lowered their Face-lifted 2009-2011. Wanted to see what it looked like lowered before I purchased the links.
Old Jun 3, 2011 | 05:16 PM
  #339
Chris-W's Avatar
sl55 AMG
Originally Posted by kamilclk430
Got to take some pictures today, just lowered the car a week ago and installed my clear markers.
Hope you like it
KAMIL
How much did yuou adjust your links on the front and rear to get this level of lowering?
Old Jun 6, 2011 | 03:59 AM
  #340
drivebenz's Avatar
Help Needed with Lowering links
I finally got the car lowered to where i want it to be; however i have a problem. every time I drive it and come back and re-measure, the car sits higher by 1/2 - 3/4 inches on all sides. I have to reset it by raising it to the highest setting and re-lowering it in order to go back to the original height I set but it never stays at that height. The minute I drive it out of the garage it goes higher and stays higher than it is supposed to. Anyone had the same problem? Please let me know.
Steve
Old Aug 1, 2011 | 05:38 PM
  #341
Chris-W's Avatar
sl55 AMG
I managed to break one of the small plastic servo legs on the front right f the car taking the OEM link off. For some reason this link was a real ***** the others popped off easily!
I now have to order a new hight servo from Merc. Also I need to tweak the car on a very flat surface to get it at the height I want.
Old Aug 10, 2011 | 08:28 PM
  #342
gearshifter's Avatar
SL500
I drive an SL500, anyone who lowered their car have that msg saying "Stop, Car too low?"
Old Sep 1, 2011 | 01:20 PM
  #343
alx's Avatar
alx
we broke on a friend's car one of the legs trying to remove a stubborn stock link. some superglue and 15 minutes later the break was just a bad memory. this was few years ago. at first i was super skeptical, but the "fix" been fine since then.
Old Dec 7, 2011 | 11:03 PM
  #344
crpdiblos's Avatar
2003 SL 500
I'm new here but I am about to do the drop. I unbolted the ball post to avoid breaking the link. I recently purchased a 2003 SL500 and the inner tires are worn through the cord with one blown out and the other ready to go and the car had new tires and was not lowered. I can only figure the alignment was done with the suspenion at the highest setting and since I drive with it at the lowest setting it wore the inner tread. Either that or the alignment guy put exactly the same amount of negative camber on both sides of the car. Now since I am going to have to do an alignment I figured I might as well drop it. I will probably make my own setup as I am in the auto fab business but I'm a bit concerned with all this talk that you can't adjust the camber. I have seen a lot of talk that the camber is not an issue and I can tell you for sure it is on any car. If the tires are running on the inside edge they are gonna wear down and relatively quickly. I've gone through enough sets of tires on dropped cars to know. So if you can't adjust the camber what do you do. I have looked at the upper ball joint and I'm thinking I can make that adjustable.
Old Dec 8, 2011 | 10:53 AM
  #345
jobe's Avatar
sl500
Originally Posted by mikeinsf
That metallic midnight blue, I think, is the nicest looking color on a R230 I've seen.
..until you park it next to black!
Old Dec 11, 2011 | 12:26 AM
  #346
crpdiblos's Avatar
2003 SL 500
Here are some pics. I made my own links. I added 6mm to the front and reduced by 4mm in the back
By crpdiablos at 2011-12-10
Old Jun 5, 2012 | 08:29 PM
  #347
X911's Avatar
CL65 '09, G55 '11
Originally Posted by mtlbenz
Yup, their 20's
winter rims)
Old Jan 14, 2013 | 09:55 PM
  #348
jbenz99's Avatar
Sold 2003 CLK 500,2003 SL 500,2006 Acura MDX,1998 BMW M3 convertible
Here is my ride using AirmaticLoweringLinks !I Them for only $135 On EbAY!
Attached Thumbnails LOWERING LINKS ?-get-attachment-12-.jpg   LOWERING LINKS ?-get-attachment.jpg
