SL/R230: LOWERING LINKS ?
https://mbworld.org/forums/sl-class-...haut-tips.html
I just installed a set ....
Fronts worked out ok.......
Rears.......not
Issue. I set both fronts the same length as well as the rears.
For fronts:
I removed the stock links, installed new.....and voila.....lowered, but left and right were different heights......played with each to get them about the same (but left side had about 4 full turns difference than right).
For rears:
Same as above, but when I now keep altering, there is NO change at all. My rear left has about 10mm longer difference than my rights, but still it is lower.
Anybody else have this issue? I drove the car around the block to see if it needed some movement to reset, but nothing........ticked as I have spent 5 hours trying to get them equal........
Rears.......not
For fronts:
For rears:
Rears.......not
For fronts:
For rears:
My real problem is with the rear driver side. No matter what I set the length to, it stays the same height. Even putting them the stock height, no dice, same height.
I started 5mm longer for fronts and 5mm shorter for the rears.
Is there a reset someplace? A fuse maybe? Stumped and irritated with these links as now I cannot get back to stock height ...
The link is a point to point link, so the male vs female side of the threaded joiner would not be relavent.......unless rubbing.....which I checked and confirmed that there is proper clearance. Unless I am completely missing something
So to be more sure how to make it work well I see those main points:
1. Put vehicle to the highest position.
2. Put links: longer side - up.
3. Lower all car about 1-1.5"
4. Put car into lowest position
5. Done
Is it right?
5. Done
Is it right?
