SL/R230: Lowering Adjustable Air Links.......
As I really don't have hours to raise, remove tire, adjust, put tire on, lower, measure, raise, remove tire, adjust, etc... I was wondering if I could get some guidelines here.
I would like to lower the front by 1.5" and the rear by 1". I understand the front links have to be lengthend to lower the front and shortened to lower the rears.
My question, does anyone know how much to adjust the links by, in comparison to the original links, to obtain the required drop above? Even considering dropping the car 1.75" front and 1.25" rear as well..........
Any help from current or past adjustable SL users is appreciated.........
but you dont have to take the wheels off once you put the links on. the front can be adjusted by just raising the car to its highest level, pop off 1 end on the link and twist it to your desired setting.
the rears are a little more tricky but you can jack it up a lil and slide under the rear tire and make the same adjustment.
FROM STOCK LINKS. I WILL HAVE TO ADJUST THEM, THE HIGHEST SETTING IS STILL TO LOW, RUBS A BIT WHEN I HIT DIPS WHILE DRIVING
HOPE THAT HELPS. ALMOST A "DO IT TILL YOUR COMFORTABLE WITH YOUR OWN SETTING"
I really want an 1.5" drop in back and a little over an inch in the front......so maybe 4mm in back and front?
Jealous seeing all those tops down. Here in Vancouver the weather has been too chilly to do that.
NICE thanks bro!!
