SL/R230: Engine missfire - Change spark plugs?
My ex-cars: 03 E55,04 C32, 05 C55 ,03 E320
I just took my SL600 to the dealer when the check engine light was on and the car lost its power. I told them to check the IC pump as well, but today they called me and told me they had to replace some coils or something which was under CPO warranty...however they also recommended me to change my spark plugs. I asked "all 24 of them?" they said "yup! you gotta change them 5 years or 100k miles or they MIGHT not going to warranty you next time if that happens."
The cost is 1300 including the labor, the car has only 32k miles and is a 2004....is it really necessary for me to do it???
As I understand it, the reason for changing plugs after 5 years even if miles are low is because of possible corrosion. You might be able to get away with removing one plug and inspect it for corrosion. If it is clean, then the other 23 should be also. If you remove the plugs yourself, be very careful removing the spark plug wire. They can be easily damaged.
good luck
good luck
You can do it yourself but it is time-consuming and a total PITA. A day's effort could pay off in saving big bucks though. Make sure to do them one at a time and label the ones you've done already. Beer will affect the 'ol memory as the project progresses. ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Rook
Rook
I guess where you're at they don't put any alchohol in those p*ssy drinks.
![tard](https://mbworld.org/forums/images/smilies/tard.gif)
Rook
// Drive through daquari shops... yes, I sh*t you not!
2007 SL550
LOL -- I guess the whole "don't drink and drive" thing is moving its way into your state about as fast as planned parenthood...
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
(Referring to a joke in an earlier thread, y'all, not attempting to make a stereotype.)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Oh and we have planned parenthood here too. Louisiana is mostly Catholic though a passer-by wouldn't be able to tell except from all the churches.
Rook
// Drinking is the official pasttime of the State of Louisiana.
![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
2004 SL600
I got the same problem. What's crazy is that over night it goes away once in a while. I already had taken it to the dealer and they told me no problems. Anyone else in know of such a thing? I'm worried, I don't have warrenty either. Exactly 25016 miles
They changed some ignition coils under warranty and fixed the problem. I went ahead and changed all 24 spark plugs (as the dealer recommended)with the body shop i go to.
2004 SL600
CRAZY!!!
Today I start the car up and a chuck of blue smoke shoots out of both my exhausts and notice my rpms go up and down. The Check engine goes on and off. Now I am really pissed. So after I pull out of my driveway the car drives fine. I just changed the oil 300 miles ago as well. Anyone might know what the problem could be? My dealership tells me there no signs of any problem. ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
