SL/R230: Glove Box Light Help
Hi,
When I was changing the light bulb in the Glove Box light on my 03 SL (R230), the spring and white clip fell out. Can someone take a picture of their light so I can put this back to together to the right way.
I have attached a picture, this is the lamp that is inside the glove box on the top. It has two notches where the clips are that you can snap it out to replace the light bulb.
If anyone can take 5 minutes to check and take a picture of their glove box lamp that would be greatly appreciated. Then I can put mine back together and not stress about it anymore.
Thanks in advance.
Thanks in advance.
I would like to help, by removing and taking a picture for you, but it may just be my luck to screw something up and break the fragile stuff.
Look at my edited picture and see if you can figure it out.
That's where the clip and spring go.
