SL/R230: retractable top wont go down
Old Aug 10, 2009 | 10:09 PM
bw53's Avatar
2005 Silver SL 500
Hey all, my top (05)wont go all the way down...stuck when almost closed....is it batteries issue??? Is there a way to close the top manually???
Old Aug 10, 2009 | 11:23 PM
FraKctured's Avatar
W203-4M W163
I had a similar issue a few years ago. I don't think there is any way to close it manually. In my case, something about the electronic control got "set" in the wrong position. A non-dealer friend advised me to start the car holding the "open close" tab, which had somehow gotten reversed. It worked, and after that, it closed completely.
Give that a try--hope it helps. Hook 'em horns. UT-A, 1996
Old Aug 22, 2009 | 07:30 PM
xternalboi84's Avatar
2003 mercedes sl500
When you pop the top off the trunk open first, and what holding it is a metal piece from the rear. I believe that piece is bent. i had the same problem. u can close your top manially but do it slow and ease or you will brake it.
Old Aug 23, 2009 | 10:43 AM
gorham105's Avatar
03 sl500
If its stuck, wont go up or down you can call you local mb dealer and they will send a technician to manually close the top for a fee.
Old Aug 25, 2009 | 12:48 AM
ttdang123's Avatar
2004 SL600; 2003 F 360 Spider
Here are the two docs that might help you?
Best of luck
File Type: pdf
Old Aug 25, 2009 | 10:56 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
Best of luck
thanks for the links!!!
