SL/R230: R230 Trunk Lock Help
Old Sep 19, 2009 | 06:54 PM
mkirincic's Avatar
2003 SL500, 1998 E320 Wagon
Does anyone have a exploded view drawing of the trunk lock mechanism. My lock makes a high pitched sound like there is an air leak and it will not automatically close my trunk lid. I do not want to bring it to the stealer. Any help would be greatly appreciated.
Old Feb 28, 2010 | 06:37 PM
wossi's Avatar
2005 SL500
If you have massage seats, that could be the problem. Sometimes one of the hoses under the seats is leaky. Or check the hoses connected at the pump.
Old Mar 10, 2010 | 08:46 AM
busaboy's Avatar
2004 SL55
You have to remove the valve/servo trunk closure assist mechanism and epoxy the multiple leaks. Many people have repaired their assist this way. I did mine a month ago. Be careful not to break anything removing it. It takes a lot of patience and some skill taking things apart.
The plastic they molded the mechanism out of shrinks over time. There are about 5 little ball bearings used as plugs in multiple plastic access tubes used in the manufacturing process. You need to totally engulf the tubes and bearings in epoxy to seal all the leaks. The cracks in the plastic are very obvious but you need to put more epoxy then you would think for future leaks.
Old Mar 10, 2010 | 08:37 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
busaboy
any pictures from your repair?
Old Mar 10, 2010 | 08:42 PM
busaboy's Avatar
2004 SL55
No pics. The competing forum has more info on the repair. Be patient and don't force anything. Lots of plastic parts that are easy to break.
