For cars that already come with factory OE 2-piece front rotors, Evosport now offers 2-piece REAR rotors to complement the package. As with all our lightweight 2-piece rotors, the Evosport setup replaces the factory OE heavy 1-piece rotors to shave 14-lbs of total unsprung weight from the rear of the car. And whereas the factory OE rotor vents correctly only on ONE side (same part number left and right), ours include a proper application for left and right so you're always venting the correct way. In addition, the vents are much larger than stock to allow greater amount of airflow.
This is an upgrade you can feel! Rotors are offered in DRILLED/SLOTTED or SLOTTED.
Factory OE Rear Rotor (each) = 20.5 lbs
Evosport 2-Piece Rear Rotor (each) = 13.5 lbs
Below are pictures from a recent install on a new R230 SL63 AMG IWC Edition finished in beautiful matte white.
For more info or to order,
CLICK HERE.
