SL/R230: Shaking!!!
Old Dec 6, 2009 | 01:51 AM
riannausa's Avatar
2001 CLK430 & 2007 350Z
Exclamation Shaking!!!
My car started shaking today as i slowly approached a full stop on a light. felt like the cars going to die on me but when i put it in neutral and gave it a bit of gas itstop shaking but did it again everytime im dlowing down and about to stop. Any HELP??? Thanks
Old Dec 6, 2009 | 03:06 AM
omar26's Avatar
E55
Could possibly be your MAF sensor
Old Dec 6, 2009 | 03:09 AM
riannausa's Avatar
Exclamation ill try!
it all started after i changed my oil. how would i know if its the MAF??
Old Dec 6, 2009 | 07:18 AM
JAYCL600's Avatar
new balance
check motor mounts
Old Dec 6, 2009 | 03:58 PM
j_belll's Avatar
‘23 EQS AMG
Originally Posted by JAYCL600
check motor mounts
Old Dec 6, 2009 | 08:32 PM
daltex's Avatar
03 SL500
Maybe a vacuum hose that got pulled loose.
Old Dec 6, 2009 | 11:10 PM
riannausa's Avatar
Hose
Wer is the hose located? No idea wer to begin I'll check the mounts then I'll keep u guys posted
Old Dec 7, 2009 | 09:21 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
So it doesn't shake when just sitting at idle? If so, then a Mercedes' service bulletin suggests your problem may be weak bushings in the mounts for the lower control arms. Weak bushings would also be indicated by a knocking sound when you drive over gravel or some types of bumps in the road.
