SL/R230: 05 SL600 Check Engine Light
Old Dec 8, 2009 | 04:57 PM
scs9716's Avatar
sl 600
Hope someone can help. I have an 05 SL600 37K miles Check Engine light with random misfires on the driver side bank of cylinders....coil module? spark plugs? had the dealr change all of it (both sides). Drove it 20 miles after picking it up, came right back on same codes.
What else could it be?
ECU?
Anyone experience this problem?
Help!
Old Dec 8, 2009 | 06:08 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
take it back to the dealer, you already PAID to fix that problem.
Old Dec 8, 2009 | 09:15 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
You are far more likely to get a constructive response if you post this problem on the Tech Help forum at www.peachparts.com. There a professional M-B tech will probably read your post and may reply to it.
Old Jul 14, 2021 | 02:04 PM
Malas7's Avatar
SL600 05
Did you figure out what it was? I am getting the exact same code, haven't taken it to the mechanic yet. All my spark plugs are brand new. Also 05 sl600.
Thanks in advance, your response might save me time and $$
Old Jul 14, 2021 | 05:13 PM
brucewane's Avatar
2005 SL600
V12 misfires can be caused by a coil pack or the Voltage Transformer/Ignition Control Unit.
There's a wealth of V12 ignition information, as well as rebuilt/improved parts, available at v12icpack.com .
Old Jul 14, 2021 | 05:24 PM
brucewane's Avatar
2005 SL600
Also - did you replace the spark plug/coil boots when you replaced the spark plugs? You really should replace the boots with new plugs. If a boot has even a tiny tear in it the current will jump to the outer coil sleeve, causing misfires.
The thing to keep in mind is that these coil packs are a bit delicate - they can easily be damaged during removal, so even though a new set of boots costs a bit extra they're worth it just to make sure you minimize coil pack removal/re-installation.
